Tractor Talk Discussion Forum
Ford 501 sickle mower
JG
07-12-2004 14:25:32
I have not purchased a manual for my 501 yet. Could someone tell me how long the pitman wood is supposed to be and maybe also what size bearings go inside the end of the pitman that attaches to the flywheel? Thanks.
Duke(WNY)
07-13-2004 17:08:49
 Re: Ford 501 sickle mower in reply to JG, 07-12-2004 14:25:32
Parts book I have shows 2 differant arms:
#149198 Pittman,long 1 1/8 x 2 1/2 x 46 7/16
#149197 Pitman, short 1 1/8 x 2 x 37 11/16
Parts books are available from 9N-2N-8N Newsletter
paul
07-12-2004 17:27:44
I have 2 such mowers, and they have different frame lengths - not sure but I believe the pitman is longer on one than the other.
I don't know about any curved piece to lean on in storage? There is a small curved rod at the near end of the sickle bar to pull grass into the mower; and there is a curved C channel for the break-away mechanism as I described on that other thread.
--->Paul
tlak
07-12-2004 18:04:03
 Re: Re: Ford 501 sickle mower in reply to paul, 07-12-2004 17:27:44
Ive owned a 14-92 and an early and late model 501 and when Ive bought sticks it was the same stick for all.
paul
07-13-2004 00:34:44
 Re: Re: Re: Ford 501 sickle mower in reply to tlak, 07-12-2004 18:04:03
And the 14-92 & 501 I have use the same belt.
So, how do they do that????? I need to look at them side by side! :)
--->Paul
tlak
07-12-2004 18:01:51
If you say the break away but on mine I did not see anything attached to it and the mower would fall over without it, maybe dual purpose. Didnt look to see if it pivoted on the frame.
tlak
07-12-2004 16:37:20
A stick measures roughly 37:3/4L X 1:5/8T X 1:1/8W
A Ford stick at NH cost about $11. They have a rivet through the tall side at the spring end. I drill the opposite end and put a 1/4" bolt to match the rivet because they seem to break out along the bolt line. I also started taping the stick with box tape because they appear to be boarder line weak. So far this season one stick. The person asking about the big curved arm toward the front that was cut off his. I believe all this was for is for the mower to lean on in storage. I have this on a salvage mower
The person asking about the bearings for the flywheel side of the pitman. I have a salvage mower that I started to renovate and bought these bearings for it. Bought about $40 sell for $25+sh.
Bernard Taylor
07-10-2005 08:41:00
 Re: Re: Ford 501 sickle mower in reply to tlak, 07-12-2004 16:37:20
Hi Are you Parting out a 501 ? I am insearch of a Pitman Drive Long or Short Reach 501 Will Work
Thanks
ChrisL
07-12-2004 14:39:36
I make mine - but they don't seem to be lasting very long lately - check one out at your local farm store....
if you still don't have any luck - I can measure and give u a rough measure
JG
07-12-2004 15:54:06
 Re: Re: Ford 501 sickle mower in reply to ChrisL, 07-12-2004 14:39:36
What lumber do you use that they haven't been lasting long? If you could measure yours for a rough estimate, I would appreciate it. Thanks.
