Tractor Talk Discussion Forum
1964 JD K181 starter and coil wiring diagrams
Kelly Leonard
07-10-2004 20:42:52
I just did the rings im my 110 JD. I also had the valves ground. My father in law and myself started putting the engine back in yesterday. We are unsure of the wiring locations. On the starter I believe there is 2 connections per post. On the coil there is 2 connections on one post and 1 on the other. Does anyone know where I can find a clear diagram of the wiring system? If anyone has some insight I would appreciate any and all advice. Thank you.
Bob
07-11-2004 10:35:56
 Re: 1964 JD K181 starter and coil wiring diagrams in reply to Kelly Leonard, 07-10-2004 20:42:52
I have a wiring diagram. Email me if you still need it. (I wouldn't be at the shop to email it until tomorrow.)
From memory...
Coil (+) post connects to wire from ignition switch.
Coil (-) post connects to breaker points, and the condensor connects to the same terminal as this wire... either at the coil or right at the points.
Starter... Large wire from starter solenoid and wire from (A) on voltage regulator to (A) on starter-generator.
Wire from (F) on voltage regulator to (F) on starter-generator.
Does this sound like the setup you have?
