Tractor Talk Discussion Forum
Long 510 oil pump shearing pins
Bob
07-10-2004 04:26:25
Does anyone have a idea or knowledge as to why the shear pin in the oil pump shaft is shearing for no apparent reason? Thank for your help Bob near Houston.
Ron
07-10-2004 05:14:59
 Re: Long 510 oil pump shearing pins in reply to Bob, 07-10-2004 04:26:25
Excessive pressure due to:
Wrong bearing clearances
Wrong pressure relief
Wrong weight oil
A more remote possibility is that the pump is damaged/defective causing it to bind.
Bob
07-10-2004 16:45:17
 Re: Re: Long 510 oil pump shearing pins in reply to Ron, 07-10-2004 05:14:59
Ron, Thanks for the quick reply. I bought this tractor new in 1982 and only have 1800 actual hours on it. No previous problems, but have heard that this shear pin going has happened before. I was pulling a hay rake when the pin sheared. With the labor involved in just getting to the oil pump, I though I would check to try to determine if this is a recurring problem and try to head it off in the futrue. I wonder if new oil pumps are available for this motor? Thanks again. Bob in Houston
