Tractor Talk Discussion Forum
1370 Case Hydralics problem
Kyle Pesta
07-09-2004 12:53:18
I have a 1370 Case and everything went dead on me except for the motor. Everything was working fine and I went work in the field the next morning and all my Hydralics were gone including the gears. Does anyone know what this is.
Dale
07-11-2004 08:18:18
 Re: 1370 Case Hydralics problem in reply to Kyle Pesta, 07-09-2004 12:53:18
Probably a torque limiter problem,Dale
nhboyd
07-09-2004 20:06:38
you may have a problem with the spines on the shaft that drives the hyd. pump. pull the pump and see if you can turn the drive from the engine if it turns without turning the engine, split the tractor at the engine and look there.
Shane
07-09-2004 17:12:32
Got fluid in it? <--- simple but possible! What do the gauges on the dash read with it running?
