Tractor Talk Discussion Forum
Charging Problem
Daniel
07-06-2004 20:19:35
I have a ford 3910 England Made Tractor I know the battery is good and charged but the trac. wont turn over with the key. You turn the key and nothing happens but when you hook the battery cables up to the batery and bypass the starter syloind it starts and runs fine. The re is a relay switch that we think is the problm but we cant be sure. I put a test light on the sylenoid and we are getting power to it but not from it. Yall think it is the syleniiod that i s the problem. If so how can u test it?
Thanks Daniel
VADAVE
07-07-2004 06:07:12
 Re: Charging Problem in reply to Daniel, 07-06-2004 20:19:35
From your discription I agree it is the solenoid and sounds like you have tested it. One other thing you can do--hook battery up normal (clean up the terminals) then jump across the solenoid, both ways. If 12 Volt from the battery to the solenoid little terminal won't pull it in and 12 volt across the big terminals starts the tractor--its the solenoid.
But based on what you said personally I would chang ethe solenoid.
