Tractor Talk Discussion Forum
Primer questions
FARMIN RED
07-06-2004 08:32:42
[Reply] [No Email]
I am working on a tractor and here is my situation. I only get to work on the tractor maybe an hour or two per week. I am working on the body work. I need to use a primer that I am able to shoot on and maybe let it sit for a week or two before I get back to it to sand it. Some one tell me what is wrog with a urathatne primer. All I hear you guys talk about is the epoxy primers. I know that there are other primers out there. I am not going to use this tractor for farm use at all. This tractor is going to be a show, paraide, and tractor ride tractor only. Some one please help.
JT
07-06-2004 09:07:56
 Re: Primer questions in reply to FARMIN RED, 07-06-2004 08:32:42
I am not a expert body man but here is what I have been doing.
Apply Acrilyc Urethane sanding primer, Sand to suit, apply Epoxy sealing primer, (I do sand this coat LIGHTLY but you are not suppose to), then apply Acrylic Urethane color.
All of these products are two part paints, either hardners or catalysts. Expect ot pay about $500 to $1000 for materials for a tractor. I spent about $1000 for the first tractor I did this way but am still using some of the primers from that project as I haven't done a tractor since:-( I am real happy with the results as things laid real nice and tractor still looks good after close to 10 years.
A couple words of caution. These paints require decent proctection equipment. I use a half mask with Charcoal filters. These can be purchased reasonable and are well worth it.
Try the restoration board or paint board here. They don't show up unless you click the button to show all the boards.
HTH
JT
BobG
07-06-2004 09:53:25
 Re: Re: Primer questions in reply to JT, 07-06-2004 09:07:56
You need to use at least a full-face mask with carbon filters. You should really use a fresh air respirator, because of the iso's.
Bob
