Tractor Talk Discussion Forum
Trans. and Differential Lube
gary christian
07-05-2004 06:26:06
Which lube do you use in the transmission and differential of a 1951 Farmall H. All Mineral 90 or GL5 80w90? The 80w90 has a sulfurized EP additive that can corrode yellow metals (Brass and Copper)
buickanddeere
07-05-2004 11:05:25
 Re: Trans. and Differential Lube in reply to gary christian, 07-05-2004 06:26:06
GL-4 is a marine lube that is blended to use with water leakage into stern drives is kinder to soft metals. Less sulphur and doesn't smell as much.
Ron
07-05-2004 08:28:59
Good thing you were aware of that before you used GL-5. If you shop around you can find the proper gear oil in GL-1. My local farm supply keeps it and NAPA stores can order it.
