Tractor Talk Discussion Forum
2-cylinder Wisconsin
Bus Driver
07-02-2004 16:52:52
Was at tractor show today. Small homemade "John Deere" about size of an L or LA. Man said had Wisconsin engine. Saw lots of 2-cylinder Wisconsin on New Holland balers in the 1950's, none sounded like a JD. This one sounded like a JD, exactly. Man said that Wisconsin made different 2-cylinder models, some with crank throws arranged like JD (one piston up while the other is down) and some with both pistons top or bottom simultaneously (this latter crank arrangement I know would have even firing order). Man said both crank styles of Wisconsin had even firing order, but he used the model with the one up, one down crank and made it fire unevenly by "cutting the cam". From what I know (or think I know) of engines, it is impossible to have a 2-cylinder inline 4-cycle engine with one up, one down crank and an even firing order. No point in arguing with the man, so not a word of dissent from me to him. But one of us is very confused. So tell me what you know of 2-cylinder Wisconsin and the crank arrangement. Is my understanding of cranks and firing orders wrong?
Bob M
07-02-2004 17:21:58
 Re: 2-cylinder Wisconsin in reply to Bus Driver, 07-02-2004 16:52:52
Yeah Bus Driver - there's 2 variations of that 14 HP, 2 cyl Wisconsin: The THD has both crank pins on the same side and is even firing. The TJD on the other hand has the pins on opposite sides of the crank so it "skip fires" (and sounds) just like like a little 2 cylinder Deere. (My apologies if I have the model designations reversed - it's been a while!)
Anyway aside from the crank, cam and distributor (or magneto...) I believe the two engines are mechanically identical.
The even firing engine has minimal pulsation in shaft speed so it's good for generators (in order to minimize flickering of lights). The skip firing engine however vibrates less since the two pistons alway travelling in opposite directions tend to cancel much of the vertical vibration. It does however have significantly more output shaft pulsation.
They're tough old motors!!
