Tractor Talk Discussion Forum
Cummins Serial Number
John
07-02-2004 07:19:36
Where is the serial number located on a Cummins 400 truck engine?
Thanks
John
george md
07-02-2004 19:37:31
 Re: Cummins Serial Number in reply to John, 07-02-2004 07:19:36
John, All the info for the engine is on the data plate that is rivoted on the block between the timing cover and the accessory drive . If that plate is missing there is a ser # on a machined surface just below the head on #6 cylinder, take that number to a cummins dealer and if they are in the mood they can tell you what that engine was , if it has not been rebuilt as a different CPL # . More important is the CPL # as it tells you what is in the block .The CPL # is also on the
tag on the fuel injection pump , Ser # won't be there, but having been rebuilding cummins engines for more than 30 years , I have not needed the ser # just the CPL # .
george
G-MAN
07-02-2004 08:36:32
Bob is correct - on the front cover area probably around the PT pump drive. What's more important than the serial number on a Cummins is the CPL (Control Parts List) number, as it specifies the arrangement of the engine and what parts are used where. If you call Cummins for parts, the first thing they'll want is the CPL number.
Bob
07-02-2004 07:29:22
Have you looked for a nameplate near the front of the LH side, on the accessory drive area?
John
07-02-2004 08:39:56
 Re: Re: Cummins Serial Number in reply to Bob, 07-02-2004 07:29:22
The only name plate I found was on the compressor. The name plate had a number that turned out to be the part number for the compressor.
Thanks
John
J.
07-02-2004 19:27:37
 Re: Re: Re: Cummins Serial Number in reply to John, 07-02-2004 08:39:56
I have not looked at one for a couple of years, but the engine number as BUILT. is also stamped into the block toward the top on the drivers side so to speak. There are 7 or 8 digits in this this number. We had a funny insurance claim one time and we took the VIN number of the truck called the manufacture and they gave us the engine number. If the engine has been changed, then you are in trouble.
lee
07-02-2004 17:08:34
unless its on the front left your hosed
