Tractor Talk Discussion Forum
Russell Bernard 64 4000
txblu
07-02-2004 06:48:25
Well I went out and checked the setup. My engine (144) has a flat sided head and the injectors and fuel lines are inside under the valve cover. So from the side of the engine all you see is 4 tubes with mounting nuts going in and one steel tube (1/8 dia or thereabouts) coming out.
The tube routs over to in front of the engine and up to connect to the bottom of a brass Tee. The side of the tee has a rubber fuel line which goes to the Roosa Master distributor type injector pump. The other end of the tee is a threaded male fitting (usually female but this is male) and it screws directly into the bottom of the tank.
I'm going to guess that this is just a tube up into the tank or maybe not even a tube.
The downward pressure on this is just gravity and that is only 1/2 psi per foot of fuel depth whereas the non used fluid from the injectors and probably the excess from the pump is at least a couple of pounds...enough to make fluid flow down the tube at a reasonable rate. So it could very well just be a battle of the pressures.
My I&T manual doesn't address the subject but I have some other manuals coming in about a week. If anything is there I'll inform you.
Sorry for taking so long to respond.
Mark
