Tractor Talk Discussion Forum
Tractor Draw Bar HP!!
Linx
07-02-2004 03:53:59
What is drawbar HP and How it is calculated?
What can be it of tractor with 57 HP & 7500 lb. wieight?
RAB
07-02-2004 13:15:05
 Re: Tractor Draw Bar HP!! in reply to Linx, 07-02-2004 03:53:59
If it was easily/accurately calculable, I am sure the Nebraska Tests would not have gone to great lengths to measure it on all the tractors tested from 1920 onwards. So I would think the simple answer is: it's guessable but not calculated accurately.
I know how difficult it is for a tractor to travel on spade lugs compared to pneumatics, so less power available for the steels to put down on the ground, but what is there is more useable, at least in some conditions.
Regards, RAB
ags
07-02-2004 07:19:22
how do torque and 4 wheel drive fit into the equation?...It would seem that more friction and therefore horsepower loss at the drawbar would occur with the addition of 4 wheel drive but actual pulling power would increase.
Bob M
07-02-2004 14:15:47
 Re: Re: Tractor Draw Bar HP!! in reply to ags, 07-02-2004 07:19:22
Good question! I guess the answer is �it depends�.
Looking at it from an engineering perspective consider this: 4WD indeed incurs higher driveline HP losses due to the extra gears, bearings, U-joints, etc. Also 4WD makes for a heavier tractor. These losses however can be offset by the reduced tire slippage and drive tire flex losses 4WD provides (you�re dividing the power among 4 driving wheels instead of 2).
Clearly 4WD increases a tractor�s overall pulling ability. However for heavy pulling in actual field conditions, I suspect 4WD does a slightly better job of delivering engine HP to the drawbar than 2WD. Otherwise why do virtually all tractors greater than about 150 HP have 4WD?
Incidentally engine torque in and of itself means nothing - you can get ANY torque you wish thru gearing. It�s engine HORSEPOWER (torque x RPM) that does the work!!
Kendall
07-02-2004 07:04:59
Drawbar HP is less because you have to account for the weight of the tractor. It does take some amount of HP to move a heavy tractor. Whats left over is HP you can use to pull something. PTO power is more because now all the engine HP is going out the PTO shaft.
Bob M
07-02-2004 06:39:23
Drawbar HP is simply the pulling power that appears at the drawbar.
Mathematically:
Drawbar HP = Drawbar pull x speed / 33,000 [pull measured in pounds, speed in feet/minute]
Under ideal conditions maximum drawbar HP will be around 85% of engine max HP. The rest of the engine HP is �lost� in moving the tractor itself, in frictional losses in the driveline, in running accessories like the hydraulic pump, etc.
txblu
07-02-2004 06:52:50
 Re: Re: Tractor Draw Bar HP!! in reply to Bob M, 07-02-2004 06:39:23
Well, as an innocent bystander watching all this at least you guys are consistent. Guess you all know what you are talking about.
However, I have seen some posted hp ratings where the engine hp on some tractors was close to the PTO(as you all said) but others the PTO was significantly less. I mentally made a note that whomever designed that rig didn't do it right and I surely wouldn't want to buy that tractor. So as procurement criteria, I would want to know all three: engine, drawbar, and PTO.
Mark
Ron
07-02-2004 09:17:43
 Re: Re: Re: Tractor Draw Bar HP!! in reply to txblu, 07-02-2004 06:52:50
Engine horsepower (BHP) is rarely published. But it just so happens that...
PTO HP divided by .86 approximates BHP
PTO HP multiplied by .86 approximates DBHP
Because PTO HP is easily calculated from a dyno pull and somewhat consistent from test to test, deriving the other figures from PTO HP is most often done.
Bob M
07-02-2004 08:32:50
Mark � there�s several factors that affect differences between engine, drawbar and PTO HP ratings:
Transmission type: Simple gear drive transmissions are the most efficient � they lose only a few % of the engine flywheel HP passing thru them. Powershifts don�t do quite as well. Hydrostatics are the worst � may lose as much as 15% - 20% of the engine�s flywheel power.
PTO design: Depending on the mechanical design PTO output may be limited to some fraction of the available engine HP. Example: I�m uncertain of the exact numbers but recall working several years ago with an older Steiger equipped with a hydraulic PTO (PTO motor-driven from the tractor hydraulics). The engine was rated at 325 HP, but the PTO was limited to 120(?) HP. Doesn�t necessarily mean it�s an inefficient design � only that the PTO mechanism is incapable of safely transmitting full engine HP.
Tires: Same as with cars, older (bias ply?) tires lose more to HP to slippage and internal flexing than do modern tractor radials. This can amount to a difference in several % in drawbar HP all other things being equal.
Weight: As with any vehicle, the heavier it is the more power is required to move it forward. So if a tractor is overballasted during the drawbar test HP will unnecessarily be be lost simply moving the tractor along (though the effect of this one will be relatively minor overall).
So simply comparing published HP ratings without consideration to stuff like the above CAN be misleading!
txblu
07-02-2004 08:46:56
 Re: Re: Re: Re: Tractor Draw Bar HP!! in reply to Bob M, 07-02-2004 08:32:50
Thanks Bob.
I never thought about the part where the designer said that we'll just rate this function for x hp rather than it just happened to come out as x hp after all was said and done with the design.
Mark
buickanddeere
07-02-2004 05:29:39
Weight only matters when figuring drawbar pull. Power is work performed over a period of time. 57 we assume is flywheel HP? Subtract losses for drivetrain friction/heating, operation of accessories and tire rolling friction. Would be in the high 40's or maybe 50HP on the drawbar.
Ron
07-02-2004 05:26:53
DBHP is the straight-line pulling force a tractor can apply to the drawbar.
The actual calculation encompasses many variables which are hard to quantify so estimates are usually made. Rather than "guess" the best way is to use the old rule of thumb; 86% of PTO hp. In your case, about 49 DBHP.
harley1983
07-02-2004 13:29:31
 Re: Re: Tractor Draw Bar HP!! in reply to Ron, 07-02-2004 05:26:53
Unless of course the course you are running on to test the static drawbar horsepower is on a 2 1/2 to 3 1/2 % grade and then the rating can either be added or suptracted from the 86% DBHP according to whether you are going uphill or downhill, whereupon one can either add 4.67% to the DBHP or subtract 4.67% as the case may be . Another variable is if the course is laid out in an east-west route and the wind is blowing from the south as it always does in Nebraska it will make a difference of approximately .96 HP per mile and hour of wind blowing. This is with a tractor without a cab. A tractor with a cab will catch more wind and then a loss of 1.27%of the DBHP muct be entered into the equasion. All of this taking into account the fact that no birds lit on the tractor during lunch hour and have added any weight to the test vehicle. YOu're right. I hate it when it rains and I have all this time to think, Harley
