Tractor Talk Discussion Forum
3pt to PTO
INCase
06-30-2004 13:32:48
I've seen lots of info on the dimensions for 3pt systems. I didn't see anything though with the dimensions from the 3pt (say lower arms) to the centerline of the PTO shaft. Does anyone have that info? THanks
JMS/MN
06-30-2004 16:50:53
 Re: 3pt to PTO in reply to INCase, 06-30-2004 13:32:48
3ph specs are at www.asae.org.
Ron
06-30-2004 15:31:01
3 pt. dimensions vary by category. PTO is in the middle.
Steve(OR)
06-30-2004 16:10:48
 Re: Re: 3pt to PTO in reply to Ron, 06-30-2004 15:31:01
So right - my implements arwe all cat 1.
Steve(OR)
06-30-2004 14:27:15
The spread is usually 26", but this is not a hard and fast standard. I have a boom pole that is 24", and a dirt scoop that is 30" (pins mounted on the inside). This makes it difficult to use a pair of stabilizer (anti-sway) bars on every implement. Sometimes I have to use only one.
