Tractor Talk Discussion Forum
Ford 4500 Backhoe Valve Clearance Tire Pressure
Rocky
06-28-2004 07:50:24
I would appreciate the recommended pressure (psi) for the 4500's (early 1970's) rear tires, it does not state on the tire itself. And, if there is an adjustment on the valves, what is the inch clearance of the intake and exhaust valves?
Thanks for any help,
Rocky
JMS/MN
06-28-2004 21:45:13
 Re: Ford 4500 Backhoe Valve Clearance Tire Pressu in reply to Rocky, 06-28-2004 07:50:24
I have a 4500 with the 16.9-28 Titan tire. It calls for a max of 18 psi. Typical pressure for that tire of any mfr is 16-20 psi. They are all in the same neighborhood. I have the op manual, but not the svc., so can't help with the valve lash.
Rocky
06-29-2004 08:14:38
 Re: Re: Ford 4500 Backhoe Valve Clearance Tire Pr in reply to JMS/MN, 06-28-2004 21:45:13
Thanks for the info. on the tire pressure.
Rocky
