Tractor Talk Discussion Forum
OT Hay, When the rain stops
txblu
06-27-2004 05:06:52
Have this field of sudan that I was able to get cut before it turned into wood (from waiting for it to dry up before cutting). Then more rain. Been a week now and the next 10 day forcast is the same; rain every day.
What do you do with the mess when it stops. Will have what was 5'stemmy grass, flat on the ground (stubble), plus at least 3 weeks of growback coming up thru it.
Hard to rake as the growback will be green and the rake will pull up some plants and include them with the mess I cut last week.
Try to bale it direct and the baler will do the same thing. Then the rolls will be just one big mess.
If I go thru it with a shredder, I can't get the shredder high enough off the ground to leave the stubble stalks for good growback; then I'll for sure be putting new hay in with the daily rained on stuff that will be at least 3 weeks old.
What to do, what to do.
Thanks,
Mark
txblu thanks and question
06-29-2004 06:24:18
 Re: OT Hay, When the rain stops in reply to txblu, 06-27-2004 05:06:52
I appreciate your taking the time to help me but now I feel worse than before posting. I can't abandon the field as the retired neighbor needs the hay.
What if I let the regrowth come on up to a couple of feet and come back thru with my haybine and start all over? I guess the haybine will pick up the stuff that was down on the 1st cutting, especially since the regrowth has pushed it up in the air somewhat. The hay quality won't be all that good but it's better than nothing. Seems our cows here eat spoiled hay as fast as good hay. Maybe it decomposes and makes alcohol and they get drunk! LOL.
Mark
mike
06-28-2004 02:58:38
best option is to just go in w/ a flail chopper and chop it on the ground. Leave the deflector in the up position so it spreads as evenly as possible.
HaySam
06-27-2004 07:26:32
GO FISHING
Sid
06-27-2004 06:37:06
This may not be the right answer but we have had that happen with and just left it caused more damage trying to clean it up than what it was worth.
steveormary
06-27-2004 16:28:11
 Re: Re: OT Hay, When the rain stops in reply to Sid, 06-27-2004 06:37:06
OT Hay;
Mabe you could burn off the field. Or does anyone close by have a loader with a stacker attachment. Then you could pile it up and feed the cows out of the stack.
steve
