Tractor Talk Discussion Forum
hydraulics won't go down
James
06-20-2004 12:14:32
I started my TO20 tractor and the hydrailic lift won't go down ubless there is a heavy implement on it. with the implement on, it lifts and goes down but as soon as I take the linkage to the control spring off the impllement the lift raises and won,'t go down. When it's down there still seems to be some jerking in the system that I have never seen before. I think the relief valve is stuck. Ay help out there?
James
Ibby
06-21-2004 04:49:56
 Re: hydraulics won't go down in reply to James, 06-20-2004 12:14:32
I'm not familier with Fergonsons, but I think they're quite similier to the 9N Ford I used to own. When mine did that, the dealer sold me a new control valve needle for a few dollars. It was a pain to install thru the inspection ports, but it did fix the problem. I'd check with the nearest parts dealer and see what he thinks.
sibby(Aus)
06-21-2004 18:11:32
 Re: Re: hydraulics won't go down in reply to Ibby, 06-21-2004 04:49:56
James, what Ibby suggests sounds right, sticky or worn control valve in hydraulic pump. How clean is your oil.? good luck, sibby.
