Tractor Talk Discussion Forum
1973 ford 3000 diesel tractor
tony baker
06-14-2004 21:22:05
When I start my tractor it runs fine until it warms up to running temptature, then it starts missing and loses power. If i shut it off then start it right back up it will run fine for a minute or two and then it starts to do it again. i drained the tank, replaced filter, and put new fuel injectors in it, but it didn't seem to help. any ideas?
Kevin (FL)
06-15-2004 12:45:37
 Re: 1973 ford 3000 diesel tractor in reply to tony baker, 06-14-2004 21:22:05
Tony,
Next time it shuts down, crack the air bleed on the fuel filter and see if it has air in it or fuel only--with no bubbles. If the filter has air in it then there's a restriction somewhere in the fuel line. Another thing to check is the fuel hose between the filter and the injection pump. My old 172 Ford had a pinhole in it and it allowed just a little air into the pump, causing erratic operation. Don't know if that model has steel tubing or rubber hose like ours, but figured I mention it as a possibility. Last thing I can think of--something wrong with the governor or the pump??
