Tractor Talk Discussion Forum
Generator wiring
Chris
06-13-2004 19:39:30
Where does the field terminal usually connect to? There is no light switch on this tractor. Does it connect to ground or do I need a regulator. My cutout relay only has two terminals, a terminal that connects to the battery and a terminal that connects to the armature. I don't know what to hook the field to.
Thanks
Bob M
06-14-2004 04:13:02
 Re: Generator wiring in reply to Chris, 06-13-2004 19:39:30
The generator field terminal SHOULD be connected to a light switch - permits the operator to select low or high charging rate. If you run your tractor only for short periods � like less than 15 minutes per start � you can get by simply by grounding the field terminal. However this can overcharge the battery if the tractor is run for longer periods.
Better solution is to replace the cutout with a voltage regulator. A regulator senses battery voltage and automatically adjusts generator charge rate as required. It�ll be $40 well spent!
