Tractor Talk Discussion Forum
Generator/ Power Steering Pump Combination
Kent
06-04-2004 22:02:15
I lost the use of my power steering on my 1957 Super 55. I found that the generator shaft that has a gear machined to operate the power steering pump has broken off. I contacted several machine shops but they said it would be an expensive repair and suggested that I find a replacement. Chevrolet has used this type of stup on their passenger cars but they are 1-1/4" longer than what is on the Oliver due to the oil filter location is right behind the power steering pump resorvior. I found that Oliver had put out a notice to all owners of this application that the releif valve in the pump is set too high and that shims were needed to correct this problem. I have installed the shims but now need armature. Does anyone have an old generator like this that they would like to sell?
J. Schwiebert
06-05-2004 05:16:48
 Re: Generator/ Power Steering Pump Combination in reply to Kent, 06-04-2004 22:02:15
Boy you bring back memories, You need to check a few other things otherwise you are going to do this real quick again. One is to change the filter in the pump. Tractor generators are the short frame not the long frame like the Chevie. Next thing are you sure your Super 55 is a 57 and not a 56 as they are different. A couple of years ago I cold still get those armature rebuilt.
