Tractor Talk Discussion Forum
Marvel-Schabler Gasket
Ron
06-03-2004 05:36:40
Where can I get the main body gasket for the up-draft Marvel-Schabler carburetor? I can get the carbureator kits from car-quest but every time I take a M-S carburetor apart that main body gasket is torn. Does any one know of any dealers or supply houses that sells just the gasket. As far as I can see these Marvel-Schabler carburetors are on about 7 or 8 of the tractors that I have. I gess there a fairly common Carb.
Thanks
Ron
don pachner
07-11-2007 21:05:07
 Re: Marvel-Schabler Gasket in reply to Ron, 06-03-2004 05:36:40
i have a 1953 vac case with marvel-schabler model ll4. there seems to be a spring loaded window covering a portion of the chock flapper. is this a required spring or if how is it fixed.. a spring was stuck on the side of the choke flapper this spring is about 1 inch long approx. 1/8 inch in diameter.. any idea on geting one of these... thanks don
Slowpoke
06-06-2004 00:50:16
Buy a sheet/roll of the correct type gasket material and cut your own.
Fred Wolfe
06-04-2004 18:54:16
I have gaskets for the small marvel schebler carbs.
Ron
06-03-2004 08:13:55
You need to start buying your rebuild kits from an AGCO dealer. They include a complete gasket/seal set. And yes, MS carburetors are very common.
harley1983
06-03-2004 06:42:12
Go on ebay, John Deere, parte, carberaters, they sell the gasket sets on there for not much money. I'm looking for a DTLX 73 or DTLX 60 for a '47 B if you have anything that will fit, let me know, thanks, Harley
