Tractor Talk Discussion Forum
Front mount pump on my Massey 135
D.W. Gill
06-02-2004 14:11:07
I am attempting to remove the front mount hydrolic pump off my 135 to replace the rear shaft bearing.(The outer race has come out of the housing) I have removed the two bolts holding the pump on the tractor housing and have also removed the bolts attaching the splined plate to the crankshaft. The pump however will not budge. I have been spraying "breakfree" on the rearbearing and have a 2 ton comealong applying pull pressure on the pump with no luck. Any ideas short of tearing the pump mount off the tractor, which is half the front end?
