Tractor Talk Discussion Forum
Long 350 trans problem
Farmerfred
06-02-2004 09:16:37
My Long tractor will slip out of gear and end up locked in reverse. I take the top off and move the shift rail to neutral, put the cover back on and it will work for a while, but eventualy gets back geting stuck in reverse.
Anyone had this problem and found a solution?
Bus Driver
06-03-2004 04:47:31
 Re: Long 350 trans problem in reply to Farmerfred, 06-02-2004 09:16:37
The shift cover that you are removing has some adjustments that can be made to it. Adjust so that everything is centered, I think you will understand when you look at it.
bill
06-02-2004 09:21:18
i have aproblem with coons, killing chickens and eating all the food, also possums. thanks for the help in advance. bill
