Tractor Talk Discussion Forum
starting problem
Jack
06-01-2004 06:39:57
I have a 1948 8N that will not start without using the choke even when it is warmed up! The carb. is a few years old and runs great. It has new wires and plugs. Can anyone help me. Thank You in advance.
RAB
06-01-2004 09:14:58
 Re: starting problem in reply to Jack, 06-01-2004 06:39:57
How are the plugs running when working? May be set too lean.
Are there any leaks into the inlet side? Check with spray on joints and listen for change in speed, or smoke if oil spray.
Regards, RAB
