Tractor Talk Discussion Forum
KUBOTA blues
carl
05-30-2004 13:13:38
Yesterday I unloaded a Kubota 225 that came from a sale 3 weeks ago. This afternoon I checked fluids and went for a test drive;everything was great till I went to hook it ti a finish mower. NO reverse!! It made a "used to the last drop" grinding noise. Is there a source of used parts or must I bite the big one for new? open to repair suggestions or use for the 22 hp diesel.
mark
05-30-2004 14:33:41
 Re: KUBOTA blues in reply to carl, 05-30-2004 13:13:38
The parts for a Kubota are fairly reasonable. It doesn't make much sense to tear the trans down and put in used gears. You probably need the reverse slider,and reverse idler and some gaskets. Parts should run around $300.
Tommy D. - Reasonable????
06-01-2004 09:14:18
 Re: Re: KUBOTA blues in reply to mark, 05-30-2004 14:33:41
Where are you finding reasonable priced Kubota parts????
EVERYTHING I have ever got for my '78 L225F has been OUTRAGEOUS! And USED PARTS?
I need to find out where you find them.
Here's just 1 Example:
My Main Input Shaft ("shaft" being the key word here) in my tranny has a gear stripped. New "kit" (won't sell just the "shaft") to fix it is $1400.00! Now bear in mind that a new Input Shaft for my Ford 4000 is $129.95!
I found a place in Kentucky that has a "lot" of Kubota parts used. Man I talked to said he'd be rich & retired if he had a warehouse of used Kubota parts - especially tranny parts!
I use my Kubota without 1/5 gear and 540 rpm PTO!
Best luck I have had is with Carver Equipment in North Carolina.
Link
chris mf135
06-01-2004 14:17:25
 Re: Re: Re: KUBOTA blues in reply to Tommy D. - Reasonable????, 06-01-2004 09:14:18
it's only 1059 at tractorsmart, i know that is still high but a lot of these dealers are really gouging parts. carvers sale prices on wsm and filters is way more than tractorsmarts price and they don't have sales.
chris mf135
05-31-2004 05:19:37
go to "tractorsmart.com" click on "check it out" then select don't know number email pdf parts list. they will email you a link to download a complete KUBOTA parts breakdown for your tractor FREE. this is the real kubota book with pictures and part numbers, you can then go back to their site and check prices and order parts, they are my local dealer and real good to deal with, good luck
Chris
