Tractor Talk Discussion Forum
Bolen Transmission, Hydraulic Gear Box Oil
Brian
05-29-2004 16:12:48
Howdy
I have a early 1980's G154 - 15 hp 3 cylinder diesel with with transmission, hydraulic and 3pt hitch all operating from the same hydraulic system.
It recently started foaming hydraulic fluid through the fill cap under the seat.
I am curious if anyone knows why this would occur.
I do not have any owners manual.
Also what type of oil is recommended for this application. The friendly Kabuto and UFA have suggested a THG oil - (transmission, hydraulic, gear).
Any assistance is greatly appreciated. Anyone have a spare owners manual?
Thanks
david val
05-30-2004 02:40:27
 Re: Bolen Transmission, Hydraulic Gear Box Oil in reply to Brian, 05-29-2004 16:12:48
foaming is usually caused by aeration- air entering the system.
could be low oil level, broken pump pick up tube, clogged intake (which ceates vacuum strong enough to penetrate seals) and bad seals especially on pump shaft and intake.
david
rod
05-29-2004 18:34:42
Usually foaming is caused by water. I use the universal like they recommended. I use 134 for all.
