Tractor Talk Discussion Forum
Bolens Gear Oil Question
D. Laird
05-29-2004 09:21:23
We are changing the hydralic/gear oil on our Bolens G272 tractor. The manual calls for SAE 80W gear oil. The only kind of gear oil we've been able to find is 80W-90 and one called Universal which says it works in all tractors. Would the 80W-90 or the Universal be all right to use? What does the 90 stand for in the 80W-90?
Ron
05-29-2004 10:25:59
 Re: Bolens Gear Oil Question in reply to D. Laird, 05-29-2004 09:21:23
75W-90 and 80W-90 can be safely substituted for 80W and 90W oil. Just be sure you get the GL right. GL4 and GL5 are easy to get but cannot always be used in place of a lower GL oil. Check the specs in the manual.
D. Laird
05-29-2004 11:00:27
 Re: Re: Bolens Gear Oil Question in reply to Ron, 05-29-2004 10:25:59
I don't see anywhere in the maintenance booklet where it mentions GL. What is GL?
Ron
05-29-2004 13:31:21
 Re: Re: Re: Bolens Gear Oil Question in reply to D. Laird, 05-29-2004 11:00:27
Gear oil specs call out for a GL-1 through GL-5. If your unit is very old, it's possible that the specs did not exist at that time. You might want to seek help from Bolens. People often think to use the highest grade sold, GL-5. It's certainly the best but can damage older units where GL-1 was intended. If it were mine, I'd use GL-4 just to be safe.
IanC
05-30-2004 18:51:11
 Re: Re: Re: Re: Bolens Gear Oil Question in reply to Ron, 05-29-2004 13:31:21
When Bolens was bought out by Troy-Bilt in the late 80's they quit importing the diesels. If your local Bolens (now owned by MTD, who bought out the assets of bankrupt Troy-Bilt) dealer wasn't around then he may not have a clue (oops, I mean service manual). AGCO/White still imports the Iseki machines as their compacts. The G272 was the same tractor as the White FB27. The dealer I worked for sold both, so we could sell a customer an Iseki with a white paint job, or a silver one. As I recall they used a "universal" fluid, like IH Hy-tran, or JD Hy-guard, but check with a dealer.
RickT
06-22-2004 09:24:05
 Re: Re: Re: Re: Re: Bolens Gear Oil Question in reply to IanC, 05-30-2004 18:51:11
Hi
I saw your post re the 272 gear oil where you said
the 272 was same as White FB27. I have a G274 and need parts, filters etc for it. 2 questions for you
1. Were the 272 & 274 similar enough to swap most parts ??
2 did White have a model # for the 274, or could I use White FB27 parts on my 274
Thanks in advance,
Rick T
D. Laird
06-03-2004 14:31:17
Thanks to both Ron and Ian for the information. Our Bolens G272 is around 18-19 years old.
