Tractor Talk Discussion Forum
Hydraulic chatter or jerking
Tomas
05-25-2004 10:07:05
I have a JD 5420 with a front loader with 500 hours on the rig. When going up, the loader goes quickly but jerky. Has full fluid and a new filter. Any ideas on what I could check? Could a dirty screen do this? Many thanks, Tomas
Gman
05-26-2004 17:26:08
 Re: Hydraulic chatter or jerking in reply to Tomas, 05-25-2004 10:07:05
Tomas what kind of hydraulic fluid did you use,John Deeres like mother Deeres oil Hy-gard any thing else your asking for trouble. Gman
tomas
05-26-2004 18:32:11
 Re: Re: Hydraulic chatter or jerking in reply to Gman, 05-26-2004 17:26:08
I was "told" it was Hy-Gard. Maybe I should start over again, as the change was made at a Ford dealer.
TomR Ont.
05-25-2004 19:26:54
I have a Yanmar 240D (hey guys it's green and old) I had a similar problem chatter and jerking only slow. The knob under the seat for the 3pt hitch was turned off soon as I opened it, the loader works fine. According to the book I have to find netural in the control leaver for the 3pt hitch and set the feed back rod. If This the Problem I could e-mail you a copy of the page.
tomas
05-25-2004 17:18:22
No, I changed the filter to try and correct it. The power steering also is jerky below about 1800 rpm's. I'll try to check for a rack or bind situation. Thanks for your ideas.
Robert in W. Mi
05-25-2004 16:50:34
Has it always done it? Or did it start after changeing to that new filter? Air in the system will cause what you are describeing too.
Robert
Joe (Wa)
05-25-2004 14:52:22
It is more likely a mechanical bind in the loader, like misalignment, a bent cylinder rod, one cylinder better than the other and out pushing.
The hyd press is equal throughout, so if there is a bind, the lift slows and the pressure rises overcoming the resistance with a jerk.
My loader is old, the left lift cylinder is better than the right which also has a slightly bent rod. With bucket mt, the left cylinder leads the right causing small but noticeable jerks when lifting.
Joe
