Tractor Talk Discussion Forum
Hydrolic Jack Oil
stan
05-21-2004 19:01:58
What will be a substitute for Hyd jack oil. I was thinking tractor trans oil.
Clem
05-22-2004 11:29:17
 Re: Hydrolic Jack Oil in reply to stan, 05-21-2004 19:01:58
Brake fluid.
RN
05-22-2004 17:10:34
 Re: Re: Hydrolic Jack Oil in reply to Clem, 05-22-2004 11:29:17
Re: brake fluid for jack oil. NO! It will probably eat seal in jack piston-unsafe. Jack oil about like 10w non-detergent oil, brake fluid glycol-more like alcahol solvent. most seals/Orings not compatible- will leak if wrong fluid used. RN
HF
05-21-2004 19:53:27
I've used auto-trany fluid for years, never a problem. But, as Bob said, hyd jack oil isn't that much more, either.
Bob
05-21-2004 19:17:09
Hydraulic jack oil is easy to obtain. Why risk using the wrong oil in a device where you could be injured, if a seal failed and the jack dropped suddenly?
stan
05-22-2004 07:21:57
 Re: Re: Hydrolic Jack Oil in reply to Bob, 05-21-2004 19:17:09
Some times doing a emergency repair in the middle of a busy season, and you find out your jack doesn't work because of the lack of oil, it would be nice to save a couple of hours, by using a good subsiitute. In my case time is money, and I most always use safety blocks, Stan
Robert in W. Mi
05-22-2004 12:30:41
 Re: Re: Re: Hydrolic Jack Oil in reply to stan, 05-22-2004 07:21:57
So buy some now, and have it on hand!
Robert
RAB
05-21-2004 23:17:16
You should never put yourself in a position where that can happen. You just need to think safety and work appropriately. Even with the correct oil, a freak failure could cause your death.
Regards, RAB
