Tractor Talk Discussion Forum
Ford 9N Problem
Tom
05-19-2004 09:37:15
I have a problem with my 9N starting and remain running. First, I have problem sometimes getting the tractor started. When I do get it started it will run for awhile maybe 5-10 minutes then it just shuts down. I'm not sure if the carb needs adjusted or does anyone think the ignition system is bad? What's an easy way to determine the problem?
Steve Mahler
05-19-2004 11:38:02
 Re: Ford 9N Problem in reply to Tom, 05-19-2004 09:37:15
I would suggest you search the archives in the Ford N section; there are a few common things to start eliminating to get an idea where the problem lies- whether ignition or fuel. My bet is on fuel.
old
05-19-2004 10:07:15
Hot wire it and if it runs then its in the ignition system if it quits its in the carb
Pitch
05-19-2004 17:52:00
 Re: Re: Ford 9N Problem in reply to old, 05-19-2004 10:07:15
On a ford if it runs for 5 or 10 minutes it is more than likely the ignition switch. By pass the switch, carefully because you will also be bypassing the Transmission interlock It will start in gear. If it keeps on running replace the switch common problem on the N series.
