Tractor Talk Discussion Forum
Kohler 14HP OHV Won't Start
Val
05-17-2004 17:14:17
Late last year my daughter stalled our Simplicity tractor out after running over some debris. Initially, when cranked, the engine would backfire through the carburetor and now it will not light at all. Engine cranks, has gas to the cylinder and when I hold the plug wire to ground spark is visible. A compression check of the engine showed about 30psi which seems low. Any thoughts? Is a valve job in order? Thanks, Val
bo
05-17-2004 17:25:26
 Re: Kohler 14HP OHV Won't Start in reply to Val, 05-17-2004 17:14:17
Pull the flywheel and check to see how bad you she sheared the fly wheel key. Timing is way off.
