Tractor Talk Discussion Forum
where's da radiator drain cock on a 2n
hot rod
05-15-2004 12:09:01
just inhereted my dad's farm and equipment due to a stroke (he's still with me though) just went to get out the 2n and i hope that last fall that he drained the block and radiator the petcock on the block was open when i filled her up with water there was a leak a the right lower corner is there some sorta drain in that area could not see where the water was coming from bout drowned trying to see up in there
RAB
05-15-2004 14:20:33
 Re: where's da radiator drain cock on a 2n in reply to hot rod, 05-15-2004 12:09:01
Well turn the **!##! hosepipe off then!
In the time you took to turn the computer on to post this you would have seen for yourself. Alternatively, go and look now. It will have all drained by now.
hot rod
05-15-2004 20:53:04
 Re: Re: where's da radiator drain cock on a 2n in reply to RAB, 05-15-2004 14:20:33
the leak was after i filled her up
RAB
05-16-2004 00:00:48
 Re: Re: Re: where's da radiator drain cock on a 2n in reply to hot rod, 05-15-2004 20:53:04
If it was after you filled it, and started it, it could be the overflow as the water expands as it heats up. Btw, if it is a leak I would think it was there before you filled it up!!
Hoping it is not a crack and that you have lots of fun with the old iron.
I don't know how much experience you have around these old things, so please be safe and enjoy it.
Regards, RAB
PS what was it - you have had time to look now.
hot rod
05-16-2004 00:54:47
 Re: Re: Re: Re: where's da radiator drain cock on in reply to RAB, 05-16-2004 00:00:48
been farming for 35 years and am ase certified mechanic. pops and i bought the 2n this past fall to restore and make a lawn mower out of. always drove dem green un's . wasn't sure what he did to winterize it, was hoping it wasn't the radiator. hoping that maybe he pulled a plug or did something that i couldn't see. hadn't had time to get back on that yet had to plant and roll some hay
