Tractor Talk Discussion Forum
STUCK CLUTCH
FRANK
05-13-2004 18:10:29
I HAVE JUST STARTED RESTORATION O A SUPER "M"FARMALL AND THE CLUTCH IS STUCK. I HAVE TORN THE ENGINE DOWN FOR AN OVERHAUL, BUT CAN,T ROTATE THE CRANK BECAUSE OF THE STUCK CLUTCH. ANY SUGGESTIONS FOR GETTING IT UNSTUCK WITHOUT SPLITTING THE TRACTOR? ALSO, CAN THE CLUTCH BE REPLACED WITHOUT SPLITTING THE TRACTOR? THANKS FOR YOUR INPUT.
Mike (WA)
05-14-2004 08:09:36
 Re: STUCK CLUTCH in reply to FRANK, 05-13-2004 18:10:29
You can usually get a clutch unstuck by taking off the starter and working through that hole, with a butcher knife with a 90 degree bend as a tool. Tie the clutch pedal down first.
Chuck
05-13-2004 19:04:27
If the tractor is not in gear the engine should still turn even if the disc is stuck. Maybe check to see transmission is really in neutral and PTO is off.Also maybe jack up a wheel and try to turn it. You don't say how much of a handle you are using to turn the crank,but it should turn over. Good luck to you.
Ray,IN
05-13-2004 21:16:57
 Re: Re: STUCK CLUTCH in reply to Chuck, 05-13-2004 19:04:27
And- tractor must be split to replace clutch. The upside is the operation is relatively easy, just time consuming.
