Tractor Talk Discussion Forum
ford 3000 3 point hitch
scooter
05-13-2004 07:50:30
Where can I find a pair of adjustable stabilizer arms for a ford 3000. They sure make it alot easier to connect implements by yourself.
Charlie
05-13-2004 11:43:21
 Re: ford 3000 3 point hitch in reply to scooter, 05-13-2004 07:50:30
Scooter
You can purchase the adustable stabilizers at Tractor Supply Co and Agri Supply here in Virginia. Check around the stabailizer bars look like the centerlink and work the same way, they are just a little smaller. I have a large st on my MF 165. You may try the dealer but they will be expensive. Try on e-bay there may be a set that will work for you. Hope this helps
RZ(WA)
05-13-2004 09:37:27
If you have access to a welder and aren't able to find any that are ready-made, a stablizer can be made from a Top Link with a piece of heavy flat-bar welded to each end if the implement pins aren't long enough and can't be changed out. Completely adjustable.
