Tractor Talk Discussion Forum
case 310 governor
Brian
05-06-2004 08:17:32
On a 1958 Case 310.
The governor is pulling the butterfly valve on the carburetor full open, engine running or not. The hand throttle does not change the position of the governor lever.
When running, the tractor wants to run at full throttle.
The throttle linkage and linkage to the carburetor are not bound.
Any suggestions�
Brian
05-06-2004 11:16:28
 Re: case 310 governor in reply to Brian, 05-06-2004 08:17:32
Stan,
thanks for your response,
to clarify:
the governor lever moves by hand with no binding, it's just forcing the carb to full throttle.
Brian
Stan(PA)
05-06-2004 09:55:34
The governer is stuck. Either mechanically bound up, or full of gunk and needs cleaned out. That's my guess anyway.....
