Tractor Talk Discussion Forum
I need you wisdom please help
Jeremy Dickey
05-06-2004 06:13:37
I have posted this question on other sites and no one has even responded any thing. I really need to know if a PTO can be installed on a Minn. Mo G-1000 wheatland that did not come factory equiped. If is can be done is it expensive, hard to find the parts, and dificult to do. I know some other modles this can be done and have on a case years ago. Thank's to anyone that responds.
kyhayman
05-06-2004 11:56:49
 Re: I need you wisdom please help in reply to Jeremy Dickey, 05-06-2004 06:13:37
Been doing some research on this (pulled out my 'never used' service manual). It shows a splined hub which bolts to the engine crankshaft (so you will have to do a split at the clutch). There is a shaft that runs back through the transmission case into the front of the differential assembly (so you will have to remove top of transmission and pull both rear axles).
Fit the pto hydraulic clutch pack into the top of the transmission differential housing and plumb to hydraulic system.
Then make necessary mods to back end of tractor to get pto shaft there.
Based on a used parts guide I have you are looking at about $800-1200 in parts. Based on the labor guide for R&R each component and multiplying times 125% (for extra time needed in conversions) you are looking at about 110 hours of labor.
Sounds to me like you have a great tractor to pull a hay rake with and need one with live PTO to run your mower and baler.
jeremy
05-06-2004 14:59:03
 Re: Re: I need you wisdom please help in reply to kyhayman, 05-06-2004 11:56:49
Thankyou very much you have no idea how much that helped. I now know what I need to do. I appreciate everyone who wrote in and hope some day to return the favor. 1000 THANKS!!!!!
Matt K
05-06-2004 10:08:29
My Dad has the same tractor. We looked at doing what you want to do. It can be done, it's not easy. The best way to do it would be to find one in a boneyard with the PTO shafts, and get everything you need from that tractor. If I remember correctly installation will require splitting the tractor and also removing the side of the differential case.
So to answer your questions in order:
Yes, it can be done.
Yes, it probably will be expensive, even with junkyard stuff.
No, parts shouldn't be too hard to find.
Yes, it will be difficult and labor intensive.
KX
05-06-2004 07:17:13
I asked the same thing on a G-705 some years ago and was told it could be done but requires disassembly of the entire rear end, pulling both axles etc. Have you asked on the MM board? there are some sharp and good guys there. Best of luck.
Van in AR
05-06-2004 07:17:12
Pop over the the Moline board and ask.
Jeremy Dickey
05-06-2004 09:59:14
 Re: Re: I need you wisdom please help in reply to Van in AR, 05-06-2004 07:17:12
Thanks but I already put it on the MM board twice and no answers so far.
kyhayman
05-06-2004 07:08:40
I know absolutely nothing about any of the MM tractors but I can tell you it wont be quick, simple, or easy even if it is possible (nothing of this magnitude is).
If you need a tractor to get hay in forget about this one except to pull a rake for this year.
COSMO
05-06-2004 06:31:39
Just so you'll get one response. I'm sorry I can't help you. Maybe that's why no one else responded. We all like to offer help if we can, even if a lot of people never bother with letting us know if we gave good advice or not.
jeremy
05-06-2004 06:39:01
 Re: Re: I need you wisdom please help in reply to COSMO, 05-06-2004 06:31:39
Thank you very much I dont wont to seem mean its just time is growing short and I am getting impatient. Just needing to figure out if I need to find another tractor so I can get my hay in.
