Tractor Talk Discussion Forum
Manifold leak?
james
04-26-2004 15:57:14
I finally got my old Fordson N running last week. It runs hot and when I pull the throttle out it splutters and almost stalls. I have to be quite libral with the fuel to keep it running. I checked the mag. timing which seems fine. The manifold has been recently replaced, is this the likely culprit? If so how to I check?
mj
04-27-2004 22:54:47
 Re: Manifold leak? in reply to james, 04-26-2004 15:57:14
Set it at quarter-throttle and the choke at whatever it takes to run smooth.....spray WD-40 around various spots on the intake (manifold to head, manifold to carb, etc.) and listen to the RPM. If you've got a leak it will change.
