Tractor Talk Discussion Forum
Fordson major flat 8 grab
Ben UK
04-26-2004 10:25:51
Hi
we have 22 acres, and make hay from a lot of it.
it would be nice to have a flat 8 grab to make hay moving a bit easier.
We have a MF135, but its probably too nice (and light) to put a flat 8 on.
We have been on the lookout for something a bit bigger, but i know it wouldnt get used much, so dont really want to spend a lot on a newish tractor.
Then it struck me that a Fordson major may be perfect, just used for loader work.
Do you think with some counter weight it would take a flat 8?
thanks in advance
Ben
JDK
04-27-2004 06:58:44
 Re: Fordson major flat 8 grab in reply to Ben UK, 04-26-2004 10:25:51
Flat 8 Grab??Not familiar with this term in USA.Is this some front mounted loose hay gathering device?Majority of hay here is swath cut w/mower or haybine,then baled from windrow(swath).Yrs back,with loose hay and stationary balers/presses,some farmers used a front mounted "sweep rake" or "hay buck" on wheels which gathered loose hay on forks which were then raised to carry the loose hay to a stack or baler.
Ben UK
04-27-2004 08:47:48
 Re: Re: Fordson major flat 8 grab in reply to JDK, 04-27-2004 06:58:44
The bales get baled in the baler. They come out of the baler and go into the flat 8 sledge. When the sledge has 8 bales in it it releases them, so you end up with groups of 8 bales all over the field (there are regular, but i wont describe exactly how a flat 8 sledge works!)
Then, a flat 8 grab goes onto the loader of a tractor. Its basically a large metal frame the same size as the flat8 sledge, with loads of big spikes in it that are mounted to a hydraulic ram.
You drop the flat 8 grab over a group of 8 bales, pull a lever which makes the ram move, and drives the spikes into the bales. You can then lift the 8 bales. Then, some people either put them onto a trailer, or put them into stacks of 8 8s, which can then be picked up by a bale transporter thing (which is also automatic using Rams) on the back of another tractor (the name slips my memory), driven back to the farm or whatever.
They are then dumped there, and can be put up into the barn by the flat 8.
Basically it means that 1 man can get atleast 3000 bales of hay a day into a barn without leaving the seat of the tractor!
