Tractor Talk Discussion Forum
Ford 4100
Russ Arnold
04-25-2004 06:46:05
What size battery goes in a ford 4100 ? we have a tractor given to us and nobody knows what battery to putb in it.
IanC
04-25-2004 10:25:51
 Re: Ford 4100 in reply to Russ Arnold, 04-25-2004 06:46:05
Gas takes a BCI group 17TF (New holland P/N F120), diesel takes BCI group 4DLT (New Holland P/N F150). Your local NH dealer should stock them both as the same batterys were used on the 2000 through 5000 series machines from 1965 through end of gas tractor production in the early 1980's. And the 4DLT was used later than that.
Leroy
04-25-2004 12:17:09
 Re: Re: Ford 4100 in reply to IanC, 04-25-2004 10:25:51
The gas takes the same 4DLT as the diesel, The 5000 took a different larger battery, I had 2 4100 gas and a 5100 gas
hay
04-25-2004 09:37:26
ford 4000/4100 takes the large truck battery. 4D i believe is the number. check with the NH/Ford dealer to be sure. my 4000 has the 4D battery. maybe a smaller one would work also. depends on the cold cranking amp output.
Russ Arnold
04-25-2004 10:23:14
 Re: Re: Ford 4100 in reply to hay, 04-25-2004 09:37:26
thank you !
