Tractor Talk Discussion Forum
Need Advice from the experts
Allan
04-23-2004 05:13:34
Hi Guys,
I'm toying with the idea of getting a 3-point, PTO driven snow blower and I've been looking at them at the Woods site.
Their info states that the 84" model takes from 60 to 80 horses to pull.
Can anyone tell me if my 60+ Hp, 686 Diesel will comfortably pull a 2-stage, 84" cut?
I�m bettin� that your real-world advice is better than what one would get from a sales brochure.
Thanks,
Allan
steve
04-25-2004 04:35:03
 Re: Need Advice from the experts in reply to Allan, 04-23-2004 05:13:34
I think you will be fine, I had a 7' farmking blower on a JD 3010 gas (55 hp) and it worked fine.when I got the 32hp kubota, I swapped the 7 footer for a 5 footer.
rfirst
04-23-2004 18:25:22
Slow reverse and chains more important than horsepower. Move snow as soon as possible after it falls.
Big Bob
04-23-2004 12:47:30
As everyone has pointed out, speed is critical. You need a two stage clutch to help you proceed slowly into deep or crusted snow, keep your revs up and take small bites, which sometimes means taking half-swaths. The hardest part is the first run-through where you have to take it all in at once.
Another note: Look at the second hand market. I bought and 80", two stage blower, early in the fall, for half of its value in early winter and a third of its new cost. Look for quality bearings with four bolts, two shear pins, good shafts and strong wide paddles. Don't worry about hydraulic cylinders on the shoot unless you have a cab or otherwise really need them. You can build a perfectly good handle to manipulate the shoot from the tractor seat for peanuts. There are many kinds. I live in Canada where we get plenty of the white stuff. I run an 80" blower on an old gas MF 50 but it has a really good motor and I do what I said above. You'll be fine with yours and have some fun to boot. Enjoy, go slow, and for heaven's sake, shut off the PTO even when you walk near the thing. I didn't do this last winter and almost slipped and went into it one night with my ski goggles on. (By the way I call my goggles the cheapest tractor cab in the world but you will need them to blow snow if you don't have a cab. And a coat with a hood on it!)
paul
04-23-2004 12:20:22
I use a 7' blower on a little 27 hp tractor, works ok here in Minnesota - have to push the clutch now & then, but that's ok. However, more inmportant than hp is that it has a really, really slow reverse gear.
If you have a slow creeper reverse gear will do fine. If you only have 1 reverse, I'll bet it runs a little too fast & you will be marginal. My good & cold snow blows a little easier than some locations with more common heavy wet stuff.
--->Paul
Matt K
04-23-2004 12:03:24
My dad has a 8' (96") 2-stage blower he uses on his 2-135 White. When he bought it he asked about a 9' blower and was told that 135 hp would be on the weak side for a 9'. Based on that I'd say 60 hp would be marginal for a 7' blower.
jdemaris
04-23-2004 05:47:34
I use a 72" two-stage three-point blower on my 32 horse I.H. B-275 tractor with no problem as far as power goes. I've cleared a lot of snow that was deeper than the blower and 32 horse was just enough to keep it going. I had to keep a path clear in my fields all winter because my short-legged goats couldn't walk through 4 feet of snow to get to the round hay bales. So, I use the snowblower. This spring, I'm finding dirt and rocks all over that it picked up and threw. Problem is ground speed. With a smaller engine, you need to keep it revved up but with some tractors, ground speed becomes too fast at high R.P.M. If you have a real low first gear things should be fine. My I.H. has a four-speed with hi and low range, but I wish it was even slower.
al
04-23-2004 05:40:56
I have an 84" two stage on a MF 65 diesel. It is ok but just barely. If I had a slower gear in reverse it would be better. As it is if the snow is more than 12" or I get into drifts I have to take less than a full width cut at one time.
