Tractor Talk Discussion Forum
hydralics
Andrew
04-14-2004 17:32:48
Is it bad to use kerosene to flush out a tractors hydralics system with it running?
Jed
04-15-2004 07:38:59
 Re: hydralics in reply to Andrew, 04-14-2004 17:32:48
I think that a gear pump would tolerate that flush for a litle while, but as I rule it isn't a smart thing to be doing. Piston and vane pumps will burn up quickly running on a light material like kero. Also be careful if you do this, the kero will vaporize and could ignite.
Ray,IN
04-14-2004 20:44:17
I use 10W oil for flushing, it's cheaper than kero.
TomR Ont.
04-14-2004 19:01:25
I had water in my hydraulic system, the Massey Ferguson dealer told me to flush it out with Diesel Fuel (not as flamable as Kerosene my opinion). Drained old hydraulic fluid (4.5 gal. system) - put in about 2+ gal. of Disel - worked all the hydraulic controls drain - repeat drain fill with new hydraulic fluid every thing is ok now. I also noticed it cured a squeal when using the hydraulic controls slow.
Make sure it is the proper hydraulic fluid for your equipment.
Bob
04-14-2004 17:43:33
No, it's not bad at all, IF you have unlimited funds for repairs!
tiny
04-14-2004 18:19:17
 Re: Re: hydralics in reply to Bob, 04-14-2004 17:43:33
Meyer snow plows recomend using Kerosine to flush out there pumps. When I did it, it did no harm ran it all winter.[ page three of the Meyer service manual Sept 1989]
