Tractor Talk Discussion Forum
Rim size needed
Howard Deeken
04-14-2004 11:45:12
I have a tractor with the rear tire size of 13.6-38, the rim is an eight loop. I need a rear rim but I have been told two different sizes 12X38 eight loop rim, and also a 14X38. Can anybody tell me which one is the correct size rim I need.
By the way the tractor is a 1966 Ford 5000. Thank You
pasbon
04-15-2004 05:36:56
 Re: Rim size needed in reply to Howard Deeken, 04-14-2004 11:45:12
I think I have some 38" 8 loop rims at home but I don't know the width. Let me know if you are interested.
Howard Deeken
04-16-2004 03:25:05
 Re: Re: Rim size needed in reply to pasbon, 04-15-2004 05:36:56
Pasbon: Yes if the rims are in good shape, I'm interested. My problem is I have one rim that is pretty well rusted around the valve. And if the tire should go flat I will not be able to use the rim I have now. Tire size is 13.6X38, I understand the rim size I need is 12X38. So let me know. Thanks
Howard Deeken
wolfy
04-14-2004 16:37:41
Dr. Evil is right on.
Dr.EVIL
04-14-2004 14:00:06
Not sure what You mean by "Loop", maybe the "Z" bars for a power adjust rim. Anyhow a 13.6 X 38 belongs on a 12 X 38 rim, a 14 X 38 rim is the approved rim for 15.5 X 38's, Way too wide for a 13.6.
Howard Deeken
04-15-2004 03:08:35
 Re: Re: Rim size needed in reply to Dr.EVIL, 04-14-2004 14:00:06
Dr.EVIL What I ment by loop is where the rim bolts to the rear wheel, and this rim has eight loops welded to it so it can be bolted to the inner wheel. Also wanted to say THANK YOU!
Howard Deeken
