Tractor Talk Discussion Forum
Alternator one wire convertion
Farmer Fred
04-13-2004 16:30:19
I have a Delco 1100668 4FI 12V alternator and want to convert it to a one wire to replace the 6V gen. I don't think this alt has an internal reg. Can I buy an external regulator without doing any interal wire changes?
Keith
04-15-2004 14:51:55
 Re: Alternator one wire convertion in reply to Farmer Fred, 04-13-2004 16:30:19
Go to the the following website. Maybe you can get your questions answer there and determine which alternator you have. Hope this helps
Keith
http://www.madelectrical.com/electrical-tech.shtml
rod
04-14-2004 08:38:33
Try here.
jdemaris
04-14-2004 05:35:11
If the plastic harness connector plugs in the top, it has an internal regulator. If it plugs in sideways in the back, it uses an external regulator.
Keith
04-13-2004 22:10:26
how many wire connections are on the back of the alternator? almost all alternators have had internal reg. since early 70's
Dick
04-13-2004 17:33:52
You Can buy a one Wire alternator , probably As cheap as You Can Buy The Regulator, The External Regulator Alternators Are a Pain In the butetty.Get A 10 Si 1 Wire & Hook To Battery + Post. You can go thru the Amp Meter Also. No Problem. Hope This helps.
