Tractor Talk Discussion Forum
8N - wiring an ammeter
Doug
04-06-2004 16:53:59
I have an older 8N with an ammeter that does not have wires running to it. I'd like to wire it up but I can't find a wiring diagram for it. Any help?
Jim.UT
04-06-2004 21:57:26
 Re: 8N - wiring an ammeter in reply to Doug, 04-06-2004 16:53:59
There are several Ford tractor wiring diagrams on the web. Here's just one site that has diagrams.
john in la
04-06-2004 18:39:08
Well it would help to know if it is original generator or converted to altenator.
Doug
04-06-2004 18:42:56
 Re: Re: 8N - wiring an ammeter in reply to john in la, 04-06-2004 18:39:08
Generator. Sorry.
john in la
04-06-2004 19:07:16
 Re: Re: Re: 8N - wiring an ammeter in reply to Doug, 04-06-2004 18:42:56
Sorry but I know nothing about the inductive ammeter on a N.
Go over to the N board and ask your question. A guy named DELL can tell you anything you need to know about it.
Pitch
04-06-2004 18:04:48
Go to the N board and type wiring diagram in to the archives search and one is there someplace.If it is original it is a voltmeter not an ampmeter and the single wire passed through the loop.
Bob
04-06-2004 18:26:57
 Re: Re: 8N - wiring an ammeter in reply to Pitch, 04-06-2004 18:04:48
The original meter with the wire loop passes through it IS an ammeter, an INDUCTIVE AMMETER.
Doug
04-06-2004 18:41:09
 Re: Re: Re: 8N - wiring an ammeter in reply to Bob, 04-06-2004 18:26:57
It does have the wire passing through the wire loop. How in the heck does that work? The gauge looks like it bounces between about 5 & 10 when the engine is at mid throttle. Doug.
Jon H
04-06-2004 20:09:27
 Re: Re: Re: Re: 8N - wiring an ammeter in reply to Doug, 04-06-2004 18:41:09
The wire running through the external loop builds a magnetic field inside the ampmeter which causes the needle to move,just as the internal shunt in a terminal type ammeter does.
I have converted many old Fords to negative ground and all you have to do is remove that heavy wire and run it through the loop in the opposite direction. Same effect as reversing the wires on an ammeter with terminals and an internal shunt. If your amp needle bounces between 5-10 amps the guage is working,and the problem if any is in the generator or whatever they use for a field resistance control.
