Tractor Talk Discussion Forum
Correct Oil
Mr Bean
04-03-2004 13:55:54
Just bought a Ford 3000 that has been setting up for 2 years. Early model gas burner. what is the correct oil to use for this tractor? Thank you in advance. Mr Bean
Brokenwrench
04-04-2004 08:43:20
 Re: Correct Oil in reply to Mr Bean, 04-03-2004 13:55:54
A GOOD QUALITY 15w-40,or straight 30W,like Rotella or Delvac will give you good results. Possibly change the oil and filter,run it for 5-10 hours and change it and the filter again to get rid of any contamination/moisture that was in the engine from sitting.You also may want to drain off any moisture that has accumulated in the tran/rear by cracking the drain plugs, and change it after 5-10 hours also.
