Tractor Talk Discussion Forum
Plow help
Farmer in the D
03-31-2004 05:53:48
third party image
Anyone have any expierience with this type or even the 142 plow? I put it here instead of implements because I would also like to hear all thoughts on how much of a tractor I will need to plow with this. Thanks for your help.
Larry806
03-31-2004 18:53:53
 Re: Plow help in reply to Farmer in the Dells (WI), 03-31-2004 05:53:48
That is a Pittsburgh ( I think) same plow as White & Case Years ago when everyone still plowed White sold the most but if you couldn't get parts just go to Case or Ford dealer What size are the bottoms they look wide to me They made some 20 inch ones. They pull HARD!
Jhill
03-31-2004 16:31:56
I pull a 4-16 plow like that one in loam ground with an 84 hp tractor with ease. If you have clay ground it you need more power. Best to see what you neighbors are using for3 similar equipment.
Jonathan
03-31-2004 06:18:02
You could problably pull that with a IH 1066, maybe alittle smaller if conditions were right or if you had 4wd.
