Tractor Talk Discussion Forum
Radial Tire Pressure
Shane
03-30-2004 04:54:34
Somewhat off topic here but we just brought home a 2390 with radials on it. They are 20.8-38's. Never had radials before and was wondering what pressure to run them at both single and with the duals. Thanks in advance!
buickanddeere
03-30-2004 07:41:39
 Re: Radial Tire Pressure in reply to Shane, 03-30-2004 04:54:34
The data is on the Firestone web site. Depends on weight and speed upon the tires. Radials can go a low as 6psi. Sure beats compacting the soil. Those farmers who won't use radials are missing out. However some people take pride in never changing thier minds or anything else. Can't explain to them that a few hundred bucks now save thousands later either.
Shane
03-30-2004 12:49:33
 Re: Re: Radial Tire Pressure in reply to buickanddeere , 03-30-2004 07:41:39
Thanks for the info. We are strictly no-till and don't really need the radial traction since we run duals on all the tractors. No-till doesn't require near the traction as pulling a disc or moldboard. However, we put new tires on all the tractors just about the time radials came out so big so in a few years they will need new ones, if these radials work like they say we may put radials on all the tractors.
buickanddeere
03-30-2004 13:33:37
 Re: Re: Re: Radial Tire Pressure in reply to Shane, 03-30-2004 12:49:33
The radials will work particularly well in the no till application. Not just the traction aspect but being able to lower the pressure and reduce compaction, keeping the soil loose for plant growth.
greenbeanman
03-30-2004 06:35:13
Quite a number of years ago I purchased the first set of radial tractor tires in my hometown area.
I had read about the benefits and decided since I had to replace my tires anyway, I'd give them a try. (Singles by the way.)
The local tire shop sold them to me for cost to get some into the local area for a test.
As I drove the tractor home from the shop I thought something was wrong with the tractor. I suddenly realized how much quietier they were when at road speed on the highway.
Pulling an 18' disc with my 1070 Case I gained a full one acre per hour. That was enough to sell me on them. Granted the old tires were well worn down which caused me to lose some of the normal traction, but a full acre? Naw!
Later a friend switched his 1066 IH to radials. His opinion wasn't the same as mine however, and the next time he had to replace tires he switched to duals without any radials. Perhaps the initial cost pinched his tight purse strings too hard.
I hope the radials work great for you. I'd like to hear some other opinions.
Bob
03-30-2004 06:17:32
Link
http://64.233.167.104/search?q=cache:ttwLtDgN80kJ:www.energy.ca.gov/process/pubs/trac.pdf+farm+tire+pressures&hl=en&ie=UTF-8
Shane
03-30-2004 12:53:05
 Re: Re: Radial Tire Pressure in reply to Bob, 03-30-2004 06:17:32
That is just what I was looking for! Thanks a million.
