Tractor Talk Discussion Forum
best loader tractor for $
west 40
03-28-2004 13:55:20
Keeping in mind some have budgets, what would say is the best used loader tractor model to look for? Some large bales, some fork work, some dirt loading, and some haybine (pto) use in hay season. Not the main or big tractor but an all around 3rd. (Goal is to stay under $5000.)Thanks
Bob
03-30-2004 07:05:16
 Re: best loader tractor for $ in reply to west 40, 03-28-2004 13:55:20
Thanks guys! Well like I said the goal was to stay under 5K. I have found several good tractors around here and no Fords. This is Green and Red country with a few MM throuwn in. Even a sprinkle of Massy and AC but older stuff. Thanks again.
kyhayman
03-30-2004 04:47:04
I definitely agree with the Ford suggestion but..... . price could be an object. Here, a decent 5000 or 5600 will bring close to $10,000 without the loader. I just sold a 1210 Case/DB with a case 56L loader for $7500 and it was no cream puff (burned valve or 2, loader frame sprung/broken/welded multiple times, steel side rails added to the tractor to hold the front end under it.)
Woodbeef
03-29-2004 16:40:38
If you want something dependable that runs,I think you will be looking quite awhile at that price. You'll need at least 50 pto hp minimum.
Roy B
03-28-2004 17:15:51
West;
I Agree with Van 5000/5600 Ford. Strong front end, reliable motor, good parts availabilty. Good units. Roy
Van(WA)
03-28-2004 17:07:57
West40; I would like to suggest a 4000 or 5000 Ford, not huge, but big enought to get a lot of work done....would stay in the 70's no older.
Toocold
03-29-2004 04:44:43
 Re: Re: best loader tractor for $ in reply to Van(WA), 03-28-2004 17:07:57
Good Choices posted. You may have to collect a few more pennies to get a 4000 or 5000. Around here a good one with a loader is 7500-9000 georges.
Go Ford.
