Tractor Talk Discussion Forum
Transporting tractors
Bob
03-28-2004 09:12:13
Hi! Do those of you who transport tractors on a trailer use chains and binders or the rachet straps? Most of the time, the distances I travel will be less than 50 miles hauling tractor/disc or plow. Thanks in advance.
kyhayman
03-29-2004 15:43:17
 Re: Transporting tractors in reply to Bob, 03-28-2004 09:12:13
I use either one. Usually for short hauls with tractors between the farms (under 20 miles)I like straps, easy to use, and I carry them anyway for hauling hay. Long trips with a tractor (if I buy one at a sale or something) or when I'm hauling backhoe/crawler/skidloader I like chain. If it's cold usually have to use chain, forgot last winter and had a set of straps freeze with the tractor strapped on.
Kevin (FL)
03-29-2004 13:59:29
Bob,
I use both--chains & binders at the four corners--crossed/diagonally arranged for better holding. Also I use the nylon ratchet-type rigs to go across the torque tube area and if possible I run one through the rear rims, right along the "6-o'clock" position. Learned that trick from a farmer/trucker in South Dakota. I like the nylon straps 'cause they're easy to set up but I've seen too many break or get cut to trust them on my tractors or anyone elses. When I do use the nylon, I now use chaffing gear underneath the straps--where ever they make a hard contact. Haven't parted a strap since I started doing that.
Oh, on the binders and chains, I use copper wire or tie wraps (cable ties) to secure any loose sections of chain and to secure a section of chain around the handle of the chain binder. I started doing this when I had a couple of chain binders "spring open" on rough roads. For long runs I use padlocks to secure the chain section around the chain binders and also to prevent anyone tampering with anything at truck stops, hotels or rest areas.
Mydeere
03-29-2004 13:43:24
As the others have said, you are much better off with a good quality chain and binder than a nylon ratchet strap.I know from experience, the nylon straps as tough as they may seem by thier weight ratings, cut and break very easily. While returning from a show with friends of mine we stopped for supper and to check the chains on the trailers when we notice one of my friends nylon straps wore completely through and in two pieces just from riding on the wheel rim of his tractor. I handed him two of my extra chains and binders for the remaining trip home. Could of been disaterous if we lost a tractor due to a broken strap.
moonlite
03-28-2004 19:48:04
Loads are to be bound in the same manner if moving just a few miles or moved across country.
John in la
03-28-2004 11:33:30
Chains and binders...preferably ratchet type chain binders for the novice hauler not the dangerous flip over type. A tractor under 10,000 lbs will require one chain on the front; one on the rear; and one on any attachments like a loader or bush hog.
While I will agree that any state can make a law restricting the use of straps on equipment; I know of none and federal law only restricts their use on hauling crushed cars.
The problem most run into and get tickets or in accidents for using them are.....
They want to use the cheap 2 inch ones that are not rated for the loads of equipment. The 4 inch straps that are needed require special ratchets that mount to the trailer and must be pulled at 90 degrees to the trailer side.
They do not use corner protectors to prevent cutting at sharp turn corners. Straps cut easily if not used properly on metal objects.
They do not have the proper type strap that has a chain and hook on the end of the strap for equipment attachment. So they tie the strap to the tractor axle or they wrap the strap part around the axle and hook the hook back to the strap. Both of which are not allowed.
Don
03-28-2004 10:36:11
You should check with your state DOT on your states binding laws. Most equipment with wheels in required to bound with chains in most states.
old
03-28-2004 09:37:34
Chains and binders, I've seen to many of those straps brake and its not pretty to see or have a tractor roll off a trailer at 50 plus miles per hour.
Greengo
03-29-2004 07:51:27
 Re: Re: Transporting tractors in reply to old, 03-28-2004 09:37:34
I would definetly NOT use ratchet straps to
haul a tractor, Use chains and binders
whether they are pull type binders or ratchet
type binders. ( Rachet binders type are better )
