Tractor Talk Discussion Forum
loader guestion
roadside ranch
03-27-2004 12:47:28
Are loaders like the f 11 or the ih 2001 or jd 148 etc more stable than the old no.30 ih loaders on narrow front end tractors. I have an m farmall with narrow front and a no. 30 loader just wondering if the loaders that sets farther a head of the rear axle would be more or less stable. For like loading large bales or just general all around use. I know wide front would be best but just wondering if it more or less likey to turn over with the newer style loaders.
rustyfarmall
03-27-2004 13:48:02
 Re: loader guestion in reply to roadside ranch, 03-27-2004 12:47:28
The newer models that you have mentioned would definately be more versatile and easier to use but under no circumstances should they be considered safer. Your tractor will overturn just as easily with the F-11 as it will with the old McCormick #30. Equipping your tractor with a wide front end will only slightly help, keep in mind that when using a loader, it is the rear wheels of the tractor that lose contact with the ground, not the front. Loader safety is all about knowing your machine and using your head.
gene b
03-28-2004 05:10:39
 Re: Re: loader guestion in reply to rustyfarmall, 03-27-2004 13:48:02
rustyfarmall says it correct it is not the equipment it is the operator.
