Tractor Talk Discussion Forum
lift capacity for 7740
wk/end farmer
03-26-2004 18:41:36
CONCERNING A '93 FORD 7740 3-PT. HYDRAULIC LIFT. I SEEM TO HAVE PROBLEMS LIFTING A 10FT. ATHENS HARROW WHICH WEIGHS ABOUT 1800LBS. THE TRACTOR LIFTS VERY SLOW IF AT ALL BETWEEN 9-1300 RPMS. NO PROBLEMS AS LONG AS TRACTOR ENGINE SPEED IS ABOVE 1400 RPMS. HYDRAULIC FLUID IS FULL, FILTER IS NEW AND THERE IS NO ASSIST CYLINDER. ALSO, THE 4 REMOTE VALVES ARE IN THE NEUTRAL POSITION. IS THIS NORMAL TO HAVE TO HAVE THIS HIGH OF RPM TO LIFT THIS KIND OF WEIGHT. THANKS FOR ANY HELP.
Dereck
03-27-2004 21:59:20
 Re: lift capacity for 7740 in reply to wk/end farmer, 03-26-2004 18:41:36
It depends w/o lift assist cylinder 1900 kg w 1 cylinder 2816 kg w 2 cylinders 3736 kg Thats out of a 1991 flyer i have
Hope this helps you,but i would test the pump ?? Good luck Dereck
ktp
08-27-2004 00:18:17
 Re: Re: lift capacity for 7740 in reply to Dereck, 03-27-2004 21:59:20
absolutely not. You have to have hydraulic problems. My 92 has 3 filters. I changed each one at a time but did not recieve top hydraulic performance until I changed the 3rd. I would recommend testing pump output if you have changed all filters. Also check fluid while tractor is running and check for cloudiness. Might indicate an air leak in your system.
