Tractor Talk Discussion Forum
how much does these wheel weights weigh
hagan
03-25-2004 18:53:36
is there a formula to figure the weight of wheel weights for tractors? I am wanting bigger weights for my 806 and have found some weights that are 29 inches across with a 13 inch center and are 3 inches thick in the center. Does anyone know how much one of these would weigh?
Rustygreen
03-25-2004 23:50:11
 Re: how much does these wheel weights weigh in reply to hagan, 03-25-2004 18:53:36
Hagan
The formula to figure the weight of a round is:
Pi X radius squared X height X Weight of material
3.1416x(14.5x14.5)x3x.258 cu.in.of cast iron 3.1416x210.25x3x.258=511.24# Now subtract the volume of the center hole.
3.1416x42.25x3x.258 =102.73# Your weight is ----- 408.51# You will have to allow for less weight if it is not 3" thick on the outer edge,anyway 400# would be be close enough.
Have Fun
Joe Evans
03-26-2004 06:07:52
 Re: Re: how much does these wheel weights weigh in reply to Rustygreen, 03-25-2004 23:50:11
Yeah, that can be tricky if the thickness tapers toward the edge. In this instance, I try to 'average' the thickness.
david val
03-25-2004 22:17:23
deoending on shape, around 400 lbs.
Keith-OR
03-25-2004 20:15:49
I just measured mine. They are 29 1/2 in diameter 10 1/2 center hole, 1 1/2 thick and they weigh exactly 100 lbs each. weighed on a certified scales. Hope this will give a fairly reasonable idea on how much yours will weigh.
bob
03-25-2004 19:25:52
probably the 80 # wts.
